RCU Forums - View Single Post - Major Glitch in a Futaba SS system!!
Old 01-05-2008 | 04:37 PM
nedyob
My Feedback: (67)
Default RE: Major Glitch in a Futaba SS system!!
Hello Moodier,
Its good that you brought this out in the open, may it be a true incident or a ficticious one. Krista replied to your post and advised what they found out with there testing of other Fasst systems, an never had a hit off another Tx unit. No you need to put your money where your mouth is and send both the units together in for a check up. It Hobby services finds the problem they rest a shured they will fix the problem under warranty.
If you choose not to send your Tx in to be checked then you are the only one responsible if someone gets shot down, and your flying club could stop you from flying at there field with out showing proof that the TX in question is fixed and given a good bill of health.
If you are doing this to try and get attention, and cause a panic, I don't think it will work. So step up and get the TX's checked out and stop trying to claim old saying " The Sky is Falling " Because after a while people will start ingnoring you and what you say.
NEDYOB
