RCU Forums - View Single Post - Major Glitch in a Futaba SS system!!
Old 01-05-2008 | 08:58 PM
moodier
Default RE: Major Glitch in a Futaba SS system!!
Hi;I have no axe to grind here but bought this unit to avoid this kind of problem!!His plane crash is the reason we found out what was happening!DO whatever you please!I am still using my FASST unit to, and like it very well,BUT i saw this situation in operation.He even went and bound the 7c to another plane completely seprate and worked fine but when the other 6 channel unit was turned on all control was lost as happened to the gasser in the air when we started ground checking the 6 channel. As I said earlier the units will all be delivered to Futaba at the Orange Co AMA meet next Friday!On there own both Txs bind and work fine only problem is they also operate the others receiver too.Hopefully there will be some simple answer to this.Incidentally the fellow whos plane crashed wrote a very polite post on the mfg.form explaining what happened and what we found afterward.It was only there for a short time,I did read it but now is gone!
