RCU Forums - View Single Post - Engine for Cessna?
Old 04-10-2003 | 08:59 PM
FLYBOY's Avatar
FLYBOY
Default Engine for Cessna?
I tend to find that you want at least the largest the manufacturer suggests. Usually that is the right size, but for some I use more if I want to throw it around a bunch. If it calls for a .40 to .60, I go the .60. I am up a bit higher so I need the power. I also like too much power and can cut the throttle.
I tend to like saito as well. Os is good as a second. Both are good motors.
