RCU Forums - View Single Post - Engine up and down thrust
Old 01-06-2008 | 11:36 AM
hulio516
Default RE: Engine up and down thrust
ORIGINAL: DavidAgar
Your problem may not be the engine. It could be the the wing incidence or the stabalizer is not mounted correctly. As for the engine, it could be mounted with some up in it, which would cause the plane to climb. You might want to get an incidence meter and check everything. If you are only dialing in a little down trim, you may just want to not worry about it and fly. Good Luck, Dave
thats where i am confused....i thought someone once told me that an engine with upthrust in it will make it decend, not climb.
sure wish i knew!
hulio
