RCU Forums - View Single Post - Engine up and down thrust
Old 01-06-2008 | 12:05 PM
Stickbuilder's Avatar
Stickbuilder
Default RE: Engine up and down thrust
If the model has a flat bottom wing, then it will climb under throttle even if you have added down thrust. If the wingplan is symmetrical or semi-symmetrical, it won't do this. If you have a laminar flow airfoil (only Pica used this on their P-51) all bets are off.
I use no down or right thrust on my planes. I use the flight controls, and throttle management to fly the plane, not let the plane fly itself.
Bill, AMA 4720
WACO Brotherhood #1
