RCU Forums - View Single Post - Excelleron 90
Old 01-06-2008 | 12:10 PM
  #769
WMB
Default RE: Excelleron 90
I found the instructions on line for the Excelleron, but it differs from the Explorer slightly. I've gone over the wings and fuse with the iron to get the covering stuck down good. This has a bottom hatch toward the rear of the fuse, any idea what that would be for? I think I will be using Hitec HS645 for everything other than throttle which will get an HS81.
This one came with pull-pull hardware for rudder and a pushrod setup for elevator. No preinstalled cable housings.
I did get a servo tray. The rudder servo will be offset to the side to make room for the elevator servo. Will this offset effect the rudder cable geometry enough to worry about it? Do the rudder cables cross, or are the parralel to each other?
Thanks, MikeB
