ORIGINAL: race_addict
thanks, and is there a certain paint that i need to use for this type of plastic or can i use many types, i hear you paint the underneath instead of top is this true. and i guess for painting it i should use clear body? hopefully that will come with some decals. Thanks alot
almost all bodies come with decals, not all redcat bodies come with decals, i got a hurricane clear body and it had no decals. Pactra is one of the biggest paint companies for rc bodies, you dont want to use a paint made for plastic or rc bodies since it will need to be able to stretch since the plastic bodies bend and you do paint the body on the inside, just make sure you wash it with some dishwashing liquid and let it dry first since oil will make the paint peel and show up on the body since your sealing it in from the inside.
