RCU Forums - View Single Post - 3D Hot Hots Build
Old 01-06-2008 | 01:30 PM
Gray Beard
My Feedback: (-1)
Default RE: 3D Hot Hots Build
My Hots is the Mid West so my wing comes off and the canopy is attached to the wing. I covered my fuse in white and blue UltraCote. I used one sheet of white for the bottom and ran it up just past the mid point. Then because of the open bay fuse I ran one strip of blue along the top then sheeted both sides with seperate sheets then did the forward section the same way with the blue. I didn't try to really hide the seams but you really do have to look hard for them. The UltraCote goes around compounds and shrinks way better then Mono.
