RE: Tornado BB pullstart and throttle
I fixed this problem by removing the pull starter, rotating it 90 degrees, and reinstalling it. The screw pattern is symmetrical, so it will work. I had to trim the opening around the engine a bit larger so the pull handle would fit. No more interference problems with the throttle linkage!
