RCU Forums - View Single Post - Anyone wear out an engine using particular oil at recommended oil ratio?
Old 01-06-2008 | 04:04 PM
tkg
Default RE: Anyone wear out an engine using particular oil at recommended oil ratio?
I have seen just one wore out gasser. It was a Q 35 and it had about 20 years on it. It had finally wore through the chrome liner, bearings and seals were OK. The oil of choice for the flier was " what was on sale". So who knows what went through it.
I have seen the results of a 1000 hr run (24-7)on a Sachs 4.2 based engine. Using dino oil at 40:1 only thing out of specs for NEW parts were the rings. Look like they would go 2-300 more hours before needing replacement.
To be truthfull about it any MODERN 2c oil will let an engine run its full rated lifetime. The wrong oil mix, carb adjustment or lack of proper cooling is what kills most new engines
