RCU Forums - View Single Post - 110 FZ problem
Old 01-06-2008 | 04:46 PM
Klonger
Default RE: 110 FZ problem
Troy
Put fuel in her today and just like you suggested the compression came right back like it should be. Next Problem: Would not start-switched out glo plug to make sure that wasn't it. All settings are exactly as they were when I put it up and this engine has always started VERY easy. Seems like it's not getting fuel, but some must be getting there to lube things up-pressure on the line from tank is there but not as much as I think it should be. If my check valve was leaking back could a lack of fuel pressure cause non starting? Cranked for quite a while at all kinds of different throttle settings and not even a pop. Haven't checked much else yet cuz it's in a cowling that I will have to take off tomorrow when I get time. Wondering what ideas you could give me to start checking on-thought there might be something obvious come to mind due to the engine sitting for quite a while and obviously getting dry. Can send it in if I need to but hoping it might be something simple. Thanks
