RCU Forums - View Single Post - Preliminary 14MZ-2.4GHz pre-flight and flying tests so far.
Old 01-06-2008 | 05:14 PM
tkilwein's Avatar
tkilwein
Default RE: Preliminary 14MZ-2.4GHz pre-flight tests so far.
I got in 3+ solid hours of ROCK solid flying in this morning. That's actual flight time counted when wheels leave the ground to touching for landing.
28F, windy and rain-snowing ocassionally. Snow is bad for 2.4GHZ freq as it reduces the signal, same as satellite TV. Used the RAYDIOWARM TX glove to protect the TX and keep it and hands warm.
2+hours of flight time in the glider and 1 hour flight time in the Banchee. Used two TX batteries up on this
day out flying.
Charging batteries as fast as the triton and tp1010c could.
Go up come down change batteries and go up again and repeat for a little over 3.5 hours of time.
I had to sit in the truck with the heater on a few times to warm my feet.
Flying in the snow with the glider as high as I could see it and no issues.
Here's a biggie, range test to over 400+ ft and still going.
""" I do not recommend this and will only do this one time """, I verified this would work on the ground 10 times before doing it in the air.
I only did it because I was the only one around as far as I could see, no traffic, no people, etc, all I had too loose was the glider and fail safe was set to go into a hard up and right turn with throttle cut. It would drop out of the sky into the lake or open space.
Again I verified going from range test to full power caused no control issues.
I power on and go into range test mode and take off (yes take off) flew for ~>500ft straight up and things started to not work right, I then exited the range test to normal power and continued to fly.
The range test output could be reduced a little more. 4-500ft ground check is a lot, and this is with the antenna pointed to the plane.
This glider will go straight up as it has over 2100+WATTS of stupid fun power to a 2lb 8oz plane. Thats a 6c 3300mah lipo strapped on the center wing
Flying the Banchee I did notice a quicker stick to servo-plane movement, controls were quick and responsive. I am only a casual flyer and I can tell, so a hot shot should be able to critic more.
Changing one model to another the trims get messed with is the only item so far and that is SW and Futaba is working on changes for the next release to fix I hope.
Definately looks like a 6014 backorder coming up.
The white spots in one of the pictures is snow.
The RX is next to the servos, Medusa 3.5A reg and CC85HV speed controller exactly as shown in the picture.
ID:	844093   Click image for larger version
ID:	844094   Click image for larger version
ID:	844095   Click image for larger version
ID:	844096   Click image for larger version
ID:	844097   Click image for larger version
