RE: Avalanche steering mod
Is it definately thicker? How do the bushings fit if its thicker. Do you need to leave the nuts a little loose because on the stock ones you can tighten them all the way. I think my steering mod will prevent this or maybe even the combination of the 2. It has bent every time the steering has locked up. Other than that it has been fine.
