RCU Forums - View Single Post - Rx Batteries selection
Old 01-06-2008 | 08:46 PM
bruce88123
Default RE: Rx Batteries selection
If you had a Spektrum I'd recommend 6 volt but since the Futaba FASST have a lower cutoff voltage I recommend staying with 4.8 volt packages but increase the capacities over "stock". If you feel you need more speed/torque from your servos then go to 6 volts AND high capacity.
