RE: 110 FZ problem
That's why I'm kinda puzzled, after I saw fuel at the carb I thought it would start. Used 2 different regular clip on type glow chargers that both checked out fine on a spare plug. Couple more questions before I try again tomorrow. Is ther a way to tell if it is flooded? Wasn't getting any fuel dripping out of the carb except when cranking with wide open throttle and HS 5 turns open-not when trying to start. Also-I noticed that the HS is only abou 1&1/8 turns out, does that seem too lean?? Guess it's possible that the HS could have got bumped since I put it up-I've got an extension with a 90 on it to clear the cowl. If so could that cause it to not even try to fire? Thanks
