RCU Forums - View Single Post - Anyone wear out an engine using particular oil at recommended oil ratio?
Old 01-07-2008 | 12:31 AM
mmattockx
Default RE: Anyone wear out an engine using particular oil at recommended oil ratio?
ORIGINAL: RTK
I would bet a pile of money that 99% of engine failures are user induced. Set your needles correctly, baffle well and supply adequate air flow. Use a good oil at manufacturers recommendations and forget it. one last thing, I prefer to use oils that mix in the range of 32-50:1
99% sounds a bit low to me...
Mark
