ORIGINAL: Hawk21
DA recomends regular fuel,
my friend DA 50 was doing the same thing inverted
at 1/4 throtle then after talking to DA we found
that the low neddle was lean so we open the neddle
and problem solve
Regular unleaded?
Do you guys think that I should use a carbon plate on carburator?
How much did you open the needle? If you open the needle too much it does not run very smoothly in the mid range.
