RE: hybrid wing problem
Mike. Here is a picture that i took last night. At this point I was in the middle of trying to diagnose the problem. This picture was taken after I saw that there was a problem. I layed a straight edge in the large groove where I will be cutting the ail. away later on. Initially, R2 was way below the rest of the ribs. I also clamped a straight edge all the way at the TE of the ail. I then raised R2 so that the cutout was in line with the rest of the ribs. As you can see, in this position, the TE of the Ail. is 5mm above the straight edge . R2 was also up off the wing root template at this point. It was very confusing.
