ORIGINAL: hitman102766
I am new to the setup of heli's. I have the B400 and stripped 2 of my eflite servos, so i bought 4 hitec hs55 servos. My ? is when i put 1 of the hitec servos on, when i add throttle, the swashplate should move down to give the blades pitch. the hs 55 makes the one side of the swashplate go up, is there a setting in the dx6i to reverse the way the servo turns??? thanks in advance. total noob ????
Yes.
Change the positive or negative numbers on the swash menu, take care of remain the same numbers just go all the way till the number changed is positive or negative, and make one number at a time to see how it changes.
I have read many posts about this problem with the B400, hopefully you will solve this issue with Hitec servos (Or metal geared metal servos like the HS65MG).
I hope this can help.
