RCU Forums - View Single Post - Fairings at the wing root
Old 01-07-2008 | 09:29 PM
iron eagel's Avatar
iron eagel
Default RE: Fairings at the wing root
This is the actual side area the duct is enclosed all the way back to just about the stock COG.
As far as I know everybody is adding a lot to the rudder, many I have seen use large counterbalances also. I had hoped that by adding to the side area ahead of the COG would be enough to improve the knife edge. Perhaps I should add a lot more rudder than I have already.
AS far as the snap with elevator/rudder I do not know I have not flown one myself, yet.
Perhaps Tall Paul could answer that question he has had several by the looks of it...
It is a tapered wing that is why I am concerned. Stock it has a real fast roll, although I have cut down the ailerons so it may not be as responsive in roll. Although I am setting up the ailerons on pull/pull so I can mount the servos 8 inches further inboard than stock to make the wing tips lighter, and keeping the most mass close in to the roll axis of the plane.
perhaps this view will help
ID:	845343   Click image for larger version
