RCU Forums - View Single Post - Preliminary 14MZ-2.4GHz pre-flight and flying tests so far.
Old 01-07-2008 | 10:39 PM
avsjr
Default RE: Preliminary 14MZ-2.4GHz pre-flight and flying tests so far.
Nice test reports!!!
I received the TM-14 and 6014 last Thursday, and updated the software Thursday night - good timing! Been using the 6 channel tx and 2 606 receivers all summer without one glitch. Decided to test the module in my 12Z on the two electrics I fly - 3D HS Extra 300 and E-flight Mini-X - the Mini-X flew without any trim adjustments at all. The Extra needed some down trim and right aileron, and was then in perfect flight trim again. Next step was the 3 year old Funtana 90 with YS-110 - which was set up as a test bed for the 72 mhz 5014 and 12Z. Just switched the receivers and went flying - however took 6 clicks of down, but then it was right back where it was on the 72 Mhz G3 receiver. Thought at first I had the trim problem that has been reported with the 14Z, but that does not seem to be a problem with the 12Z software.
Right now I am really happy with the setup, and glad I waited also. I ordered the module and receiver June 1st, and almost cancelled it a number of times.
Andy S.
