RE: Skydrill kit build
Once the ribs were glued down, I placed the bottom spar piece into the slots and glued it in place, followed by the trailing edge sheets and leading edge sticks. I made the shear webs from 1/32" sheet and glued them in as per the plans. I removed the pins, turned it over, and added the top trailing edge sheets and 1/4" trailing edge sticks. Also added doublers to the center nose rib per the plans. That's all for today.
