RCU Forums - View Single Post - O.S. 40 lost compression
Old 04-11-2003 | 05:37 AM
William Robison
Default O.S. 40 lost compression
BC:
As I said, just run it and see what it says.
Also, if you are running synthetic, try the Omega 15% nitro - it's part castor oil, helps seal things when they get a bit loose.
If that last flight was a lean run, the engine could be damaged and have the damage bear no relation to the crash.
Just use some castor, run it and see.
Bill.
