RCU Forums - View Single Post - JetJoe OWNERS thread
Old 01-08-2008 | 07:38 PM
  #1431
knobby1
Default RE: JetJoe OWNERS thread
ORIGINAL: GeeBeeJim
Smithy, real nice close-up shots of your set up. I see the filter, and I'm finally getting the other components sorted out. I can't thank you enough.
What is that between the gas solenoid and the engine. Just a manual shut valve off maybe ?
> Jim
Jim,
The valve between the gas solenoid and engine is just a Festo regulator or more correctly, an adjustable restrictor, I use it to regulate the amount of gas during the start sequence, I find it's very usefull when changing out empty gas cans, once I had the adjustment set correctly, (took me three or four starts to get it right), I can now just change gas cans and not worry about adjusting gas flows, pretty much a set and forget affair, works a treat too! Alternatively, you could fit a fixed restrictor in the gas supply line, something like 0.5mm or so, I believe some engine manufacturers do this allready. I like to turn my gas supply off when the engine isn't being used, simply because if a solenoid fails to close completely after shutdown, you'll get small amounts of gas leaking through the engine, not only is it a fire hazard, it wastes your gas too!!
I guess it comes down to the type of gas you're using and the pressures supplied by the can itself, no two set-ups would be the same I expect so each individual system would need it's own fine tuning to get it right.
Cheers,
Smithy.
