RCU Forums - View Single Post - JetJoe OWNERS thread
Old 01-08-2008 | 07:44 PM
  #1432
knobby1
Default RE: JetJoe OWNERS thread
ORIGINAL: Ruizmilton
Brett:
Can you please tell me the size or diameter in mm of the JJ1800 starter motor can? I'm doing an autostart conversion of a big turbine, I tried the starter of my JJ1400 but the 300 series motor is not powerful enough to rotate the turbine shaft as required. I need to validate it's a 400 series, 28mm in diameter, if so I will order a starter pod from Gabe.
Hey Ruiz,
As FW has mentioned, the starter is indeed "a tick under 28mm" something like 27.85mm or so. They seem to turn the 1800 quite nicely, when mine finally gives up the ghost I think i'll get a good quality Graupner to replace it, unless anybody has any suggestions othwise!
Cheers,
Smithy.
