RCU Forums - View Single Post - Angel S EVO Build Thread
Old 01-08-2008 | 09:26 PM
Jeff Boyd 2's Avatar
Jeff Boyd 2
Default RE: Angel S EVO Build Thread
You could still use the motor . . I would. Just run a band-saw through the middle of the motor box and shorten it the desired length using balsa traingle stock in the four corners.
The Hyperion motor is dimentionally exactly the same as the Hacker. Bolts straight on. As a matter of a fact, the specs for the motor are very close just 100kV more which is perfect for the 5S pack. Would almost bet that this series of Hacker and Hyperion outrunners are made in the same factory. They sure look close.
