RCU Forums - View Single Post - Will a DF powered hydro work
Old 04-12-2003 | 04:41 AM
raiki
Default Will a DF powered hydro work
What sort of cat hull would you use?? How about a tunnel hull?? Point me to some plans or even some pics of the type of hull you are refering too.
I realise the full size turbine powered hydros use a turbo shaft like a turbine chopper but I was hoping my hydro would float about an inch ABOVE the water so a stardard marine prop just wouldn't cut it.
How about a hydro foil type boat, now that would be fast (Assuming it ever got fast enough to get up on the foils.
