RCU Forums - View Single Post - CA Warning
Thread: CA Warning
Old 01-09-2008 | 10:08 AM
Don41's Avatar
Don41
Default RE: CA Warning
ORIGINAL: sscherin
Anyone think that a Delta or Jet Air Filter system would help?
http://www.amazon.com/Delta-AP100-Sh.../dp/B0000EI96M
I know the wood workers like em.
I don't have any issues with CA fumes.. I'd like it to stay that way.
Running my 3hp Dust collector would be a bit overkill for fumes but I was thinking of making a down draft sanding table that I could hook up to it.
It would eliminate fumes and dust but may also suck up small parts..
I have doubts this is the system you need for CA but I haven't seen it up close and personal.
Basically I suspect that all you truly need is to use the precautionary methods mentioned by others,,, a good strong fan drawing air away from the work area and out a window. Of course this time of year can make that a problem since the fresh air you'll be drawing into your shop will be ice cold.
[Also, don't forget that the chemicals can also get into your system thru the skin.] I used the debonder many times yet I have never checked on its toxicity. Has anyone else?
