ORIGINAL: fw190
I wish i can do something about the fish tailing! tried all kinds of HH setting and lowering the gryo value made the wag even longer in between. I have mine set at 55 on the gyro, anyone find a good setting?
Are you using a stock eFlite servo or an upgraded digital DSP75? As you may already know, and from what I hear, the stock servo will not work in HH mode with the gyro. Something about it not excepting the signal pulse of 275hz, which is needed for HH mode. Otherwise, you work in rate gyro mode only, regardless of settings. Anyway, if you haven't, you might try switching to a DSP75 tail servo. Just FYI and someone can correct me, if my understanding is wrong. I'm by no means an expert.
