RE: CA Warning
Fishin: Even if I weren't allergic to CA I'd prefer Titebond III for gluing sheets together. I make sure the edge is a good fit, lay masking tape down on one side, fold the two pieces away from one another, add Titebond (or similar), lay back down on a flat surface and weigh it down or pin it. Don't forget to clean as much of the glue off the surface as possible.
Go get a cup of coffee and tinkle. (:-)
I find that the glue has stuck fairly well by the time I return (but I'm not suggesting to unpin it yet). I prefer this type of glue because it sands so well as opposed to the hard joint typically left by CA.
