Flip 3D Setup
Thanks - I was going according the manual and it shows the cap screw with the wheel on it and then two nuts on the cap screw - the nuts go up the thread and stop at the bare part which leaves way too much for the wheel to spin on - in fact - this setup won't allow for the correct spacing for the metal gear frame to connect the wheel and pant - there is too much screw inside the pant.
So what you are saying is blow off the instructions?
Thanks again,
Dan
