camera pivot
Ok. stupid question of the day:
I've gotta CVS cam that I've rubber banded on and packed in the canopy with foam depending on the model. It works.... alright I guess that way.
Now for the next step and before I spend any money I'd like your opinion.
Under the canopy there is a balsa floor. I think what I'd like to do is mount the camera on a servo through the floor of the cockpit.
I've gotta Airtronics 6ch. My options are:
Run the servo off the rudder channel with a Y. I don't know if that's such a good idea really for the obvious reason.
Run the servo off the two position retract switch.
Run the servo off the three position flap switch (which is in use right now, but CAN be changed)
The way I figure option #2 and #3 is the only way with my current radio. SO, you think i'd work if I got one of those servo slower-downer things I've seen advertised for the pan?
With the retract switch, I'd have left (or close to it) and 180deg right(or close to it)
With the flap switch I'd have left, center, and right.
Does it sound like a good plan? Or should I use the foam and rubber bands?
