ORIGINAL: SaVaGe MaN SS
yeah you can use them make shure you buy the nuts also
What nuts do you mean? That should fit right onto the axle shaft and into a 17mm wheel right? The only difference i can see is that the warhead uses 2.2mm wide shaft pins, while the savage uses 2.5mm. I'm not sure if it'd be a problem to use the original warhead pins. There would be a tiny bit of play in the hub.
