RE: servo extension
I use shrink wrap electric tubing. Just cut a piece about 3/8 of an inch longer on both ends, slid it over the connector, heat it with a heat gun. This is only recommended if you don't plan on disconnecting these leads on a regular basis. If you do need to disconnect the leads secured this way then very carfully slice the shrink wrap over the plastic ONLY and tear the rest off.
