Short Crappy vid of the aluminum skis on the Snow.I tried to vid, and operate all at the same time ..(Note To Self) Don`t.!! .LOL Kind of shows that, they scoot along really nicely, at low power.
http://www.rcuvideos.com/item/6YS1W4BTW7RLVXXT
Well got the gunwales made didn`t go exactly as planned, but It`s a proto-type,and I needed to make tools so that I could Form their Shape.That took time.I actually Work Hardened, one small spot on the side of the hulls Gunwale, and it cracked from over working 1 area, a little too much..That`s ok too because I now have the Feel for doing the Job without a problem on the Final version.. The next boat will go much quicker build wise now that I have things figured out more or less..I reconsidered the wood thing .I might use a bit (Wood) just to speed up the Proto Build, and get this Boat powered and Testing..For all I know,I might be wasting my time on this design, and have to Redesign it altogether, so, No sense wasting time, and Material without seeing this build in action first.I`ll make whatever changes that might be Needed, then do my entire build out of Aluminum,as originally planed.
Pic explain themselves,I think,and show where I`m currently at.. I wonder if my SuperTigre G90 will be enough power, to test this Hull with.? [&:] I would hate to be under powered...
