Wing covering is done. I don't think I'll have any problems with orientation in the air on this one.
I need to order some more covering as I underestimated the amount needed. I have enough to get the tail done. I may just run down to the LHS and see if they have some. I'm waiting for payday to order the flight pack. I plan on using a 6volt pack with HS-475HBs on the control surfaces and a standard servo for throttle. If the plane comes in between 5 - 5.5 lb, I'm going to use an SK 50 that I already have. If it's any heavier, I'm trying to decide between an OS 55AX or a Magnum 70 FS (both are $149). I currently have a 5lb fun fly that has an SK 50 on it and I never get above half throttle with it, so if the weight is right I'd like to use that engine to keep it light.
