RCU Forums - View Single Post - Wood or Nylon props?!
Old 01-10-2008 | 03:48 PM
Jburry's Avatar
Jburry
Default RE: Wood or Nylon props?!
Master Airscrew and APC props are both versions of glass filled nylon. Basically nylon with bulk glass fibre in it for reinforcement. Common material for many mid-high strenght plastic apps.
With smaller engines, I always use a nylon prop, the small engines are inexpensive to repair, and actually I've not damaged one yet due to propstrikes. On gassers and other larger engines, wood seems a safer bet for the engine.
Wood props are lighter and really help the gassers accellerate much better. I've got a few 18x8 props. The wooden zinger weighs about 90g. The MAS weighs almost 150. Engine throttle response is markedly different between the 2 (G-38).
J
