RE: axe cp thread
Thank you guys! I think my pitch problems may be solved! I havent flown it yet, but the servo on the right side, when looking from the tail, was about 3 notches too high. I took the servo arm off, turned the radio on, then plugged in the battery (motor leads off). Re-centered the servo arm. Now, at full throttle, I definitely have positive pitch, and at no throttle, zero pitch. Moving the servo arm seems to have levelled the swash as well.
I think im going to take it outside and spin it up and see what happens. I will let you know.
Thanks again for the detailed info, I really appreciate it!
Greg
