RE: single-rotor stability sorta solved
Adding weight to the paddles themselves does the same thing as adding collars. The only difference is that the collars need more weight for the same amount of effect because they're a little further in but the underlying principle is the same. If you want to add more stability and are pushing the limit in terms of weight, you can also use a longer flybar.
