RCU Forums - View Single Post - Angel S EVO Build Thread
Old 01-10-2008 | 08:26 PM
jfetter
Default RE: Angel S EVO Build Thread
Here is a shot of the air exit holes in the bottom of the fuse, this will allow a massive amount of air to flow through the cowl, across the motor, battery and finally out the bottom. From what I can see, this should be the coolest setup I have (temperature-wise) as the entire design from the ground-up is meant to get adequate airflow...
Jack
