RE: g-23 carb problems
Since the engine is somewhat of an elder statesman the seat could be dirty causing the valve to stick in the housing or simply worn. Maybe you overlooked something during your rebuild so a check with your small engine repairer or the like should get you going in no time. If not, a replacement carb might be on the cards.
Karol
