RCU Forums - View Single Post - Inverted engine on Q-40
Old 04-15-2003 | 12:15 PM
kane
Default Inverted engine on Q-40
Don,
I wouldn't worry about the spinner. THE AIRPLANE SHOULDN'T BE ON IT'S NOSE!
Big kudos for the "prima Donna". I just got it! Sometimes Duane is too smart for his own good.
With the bubbless tanks I don't think tank location is as critical as it was before. The Jett CG tank should be perfect. It is flat and compact. You shouldn't have to notch anything.
I agree that the 5" rule has opened the door to different choices in airplane design. There are several out there.
I honestly, don't know how you do it. How much sleep do you get? It sounds like you don't need another project. Duane you have an abundance of time you do the Smoothie.
Dan
