RCU Forums - View Single Post - Ignition cut-off question?
Old 01-11-2008 | 08:29 AM
tail strike's Avatar
tail strike
Default RE: Ignition cut-off question?
Make sure the ends of the FO cable are cut square with a sharp razor blade.
I believe you have your ATV set to high. Bring them back till they are at zero then put the gear switch in the position you want for on
and advance the atv toll the led comes on, then flip the switch to the off position and advance the atv till the led goes off, done
