RCU Forums - View Single Post - Fairey Rotodyne again... ;-)
Old 01-11-2008 | 08:33 AM
XE521's Avatar
XE521
Default RE: Fairey Rotodyne again... ;-)
Grussti Philipp,
the only thing I can come up with is in effect a joy stick mechanism, wereby the joy stick is the rotor shaft. The potentiometers would be replaced by servos. But this leads to a problem, either you use very strong, heavy, servos or a gear-box to up the torque. If gear-boxes are used then this will slow down the reaction time. I may well be wrong, but as far as I can see if you use any other form of control then you will run into non-linear movement.
Why don't you use a heli swashplate? Simpler, also lighter servos and less weight.
I'll be watching this theme as I also have an interest in this matter.
If you need drawings, large scale, of the original aircraft just PM me or send an email.
Servus.
Karl.
