RCU Forums - View Single Post - A CHRISTMAS BTE VENTURE BUILD/MAIDEN FLIGHTS
Old 01-11-2008 | 10:48 AM
airbusdrvr
Default RE: A CHRISTMAS BTE VENTURE BUILD
This is the last entry for any updates on this plane. The plane flies much straighter with a shim to add right thrust(engine angle noted above). The wheel pants are not going to be added. While preparing to install them I just decided they would not be worth the effort and the problems associated with wheel pants. I already had the holes in the landing gear leg drilled to install the pants when I said no to the installation. Today's five flights proved the engine angle is now good. She flies well, take offs and landings are a breeze.
