RE: 1/4 scale Gas Tunnel boat ... what to build?
Hi OB
Yes it is the latest type Lawless set up. I have been working with Fred on this for some time now.We have found the set p to be critical with shaft lenghth etc, however Richard in the UK is having no problems. Lube is on placement high speed grease thereafter 50/50 gear box oil and STP no smoke.
If you are serious about been on the podium call Fred for some instant bolt on power as in a pipe purpose made for the out board.
Good luck with your race.
regards
Dominic and Lisa-Marie
