RE: .12tz carb restrictor/ break in on crt.5
Thanks for the reply but i thought that when u get a new engine the cylindar and housing are not perfectly seated properly and if u were to run it at high throttle this would not allow the metals to seat correctly or even worse you could score the cylindar and loose compression. Is this true?
