Set the booms hold ing the rotor heads at about +15 degrees and tilt the rotor head pins (shafts) out about 4 degrees. This will help the rotor blades clear the booms.
Phil
Good point, I had not thought about tilting the head pins outward to clear the booms. Thanks.
