RCU Forums - View Single Post - Angel S EVO Build Thread
Old 01-11-2008 | 06:19 PM
jfetter
Default RE: Angel S EVO Build Thread
More shots of the Hacker A50 14L and Jeti Spin 75. The motor box was shortened by 10mm (it was quite easy after all) so the clearance is now eactly that same as if using the standard A50 16S that the model was built for. The ESC is simply mounted to the underside of the engine box with a wire tie, plenty of air flows over this area so there shouldn't be any issues with cooling.
Jack
ID:	848444   Click image for larger version
