Hi, thanks for the replies, I will give Tail strikes Ideas a go, as far as calling ya I would have but I found the problem at about 8pm last night ( about 20 mins after I took it out of the package )
. I made a post on the forums here cause I believed that I was most likely at fault and figured I could get some help that would benefit others as well. There is also the chance as I said that the transmitter may be faulty, which as we all know can happen from time to time also, bad solder joint, faulty transistor etc. anyway I will go give that I try and post here again.
thanks alot for your quick reply
